Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Slide the switch on the left side of the battery to the left.
Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
Once all the clips are released, remove the bottom cover.
Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
Unplug and remove the battery connector from the motherboard.
Remove the internal battery.
Unplug the cooling fan's cable from the the motherboard.
Using a Phillips #00 screwdriver, unscrew five 4.6 mm screws fastening the fan and cooling pipe.
Remove the cooling fan directly upwards from the core.
Using a spudger, pop off the gray and black coaxial cables from the Wi-Fi card.
Using a Phillips #00 screwdriver, remove the 3.6 mm screw from the Wi-Fi card.
Slide the Wi-Fi card out from the socket on the motherboard.
Pull the two tabs on either side of the RAM card outwards with your fingers.
Pull the Wi-Fi card out from the port by the edges of the card.
Remove the RAM module from the laptop.
Repeat the same process for the second RAM module if your computer included one.
Use a Phillips #00 screwdriver to unscrew the three 3.3 mm captive screws securing the keyboard.
Use a Jimmy to pry under the top left corner of the keyboard.
Continue prying along the top edge of the keyboard, releasing the clips as you go.
Once the top edge has been fully released, grab the top edge and hinge the keyboard upwards on the bottom edge.
Pull the keyboard away from you, releasing the tabs along the bottom edge.
Flip the keyboard over to rest face down over the trackpad.
Use a spudger to lift up the two black, hinged locking flaps on the ZIF connectors on the motherboard.
Use a pair of blunt nose tweezers to pull the two keyboard ribbon cables out from the ZIF connectors.
Using a Phillips #00 screwdriver, unscrew the three 3.3 mm motherboard screws.
Using a Phillips #00 screwdriver, take out the port clamps and the three 3.6 mm screws.
Flip up the two ZIF cables for the trackpad and fingerprint sensor with the pointed end of a plastic spudger.
Pull out the two ribbon cables with a pair of blunt nose tweezers.
Using a spudger, flip up the locking tabs of the two ZIF connectors on the upper left corner of the motherboard.
Pull out each of the ribbon cables using a pair of blunt nose tweezers.
Flip up the locking tab of the ZIF connector on the bottom left of the motherboard.
Pull out the ribbon cable and speaker cable from their connectors using a pair of blunt nose tweezers.
Using a spudger, flip up the locking tab of the ZIF connector in the top right corner of the motherboard.
Pull the ribbon cable out from the connector with a pair of blunt nose tweezers.
Using a Phillips #00 screwdriver, remove the four 3.6 mm screws holding down the port brackets on the right and left sides of the motherboard.
Remove the two 3.3 mm screws from the motherboard with a Phillips #00 screwdriver.
Lift up and remove the motherboard.
If your replacement motherboard does not include a CMOS battery, you may need to move it over from your old motherboard. You can follow this CMOS Battery Replacement guide if you need help!
