Ir para o conteúdo principal
Lenovo ThinkPad T580 Internal Battery Replacement
O que você precisa
  1. Lenovo ThinkPad T580 Internal Battery Replacement, External Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T580 Internal Battery Replacement, External Battery: passo 1, imagem 2 %32 Lenovo ThinkPad T580 Internal Battery Replacement, External Battery: passo 1, imagem 3 %32
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Internal Battery Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T580 Internal Battery Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T580 Internal Battery Replacement: passo 2, imagem 3 %32
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Internal Battery Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T580 Internal Battery Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad T580 Internal Battery Replacement: passo 3, imagem 3 %32
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Internal Battery Replacement, Bottom Case: passo 4, imagem 1 %32 Lenovo ThinkPad T580 Internal Battery Replacement, Bottom Case: passo 4, imagem 2 %32
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Internal Battery Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T580 Internal Battery Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T580 Internal Battery Replacement: passo 5, imagem 3 %32
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Internal Battery Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T580 Internal Battery Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T580 Internal Battery Replacement: passo 6, imagem 3 %32
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Internal Battery Replacement, Internal Battery: passo 7, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 Internal Battery Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad T580 Internal Battery Replacement: passo 8, imagem 2 %32 Lenovo ThinkPad T580 Internal Battery Replacement: passo 8, imagem 3 %32
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
Conclusão
Uma outra pessoa concluiu este guia.
Ben Elkayam
Membro desde: 01/23/20
912 Reputação
8 Guias de autoria
Equipe
Cal Poly, Team S18-G6, White Winter 2020 Membro de Cal Poly, Team S18-G6, White Winter 2020
CPSU-WHITE-W20S18G6
4 Membros
18 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 107
Últimos 30 dias: 447
Duração total: 5,666
