Ir para o conteúdo principal
Lenovo ThinkPad T560 Back Panel Replacement
O que você precisa
  1. Lenovo ThinkPad T560 Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
    Pergunte ao FixBot
    Comentar
  2. Lenovo ThinkPad T560 Back Panel Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Clemson, Team 1-3, Hunter Spring 2022 Membro de Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 47
Ao todo: 1,720
