Ir para o conteúdo principal
Lenovo ThinkPad T490s SSD Replacement
O que você precisa
  1. Lenovo ThinkPad T490s SSD Replacement, Loosen the back screws: passo 1, imagem 1 %32 Lenovo ThinkPad T490s SSD Replacement, Loosen the back screws: passo 1, imagem 2 %32
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s SSD Replacement, Release the clips: passo 2, imagem 1 %32 Lenovo ThinkPad T490s SSD Replacement, Release the clips: passo 2, imagem 2 %32
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s SSD Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T490s SSD Replacement: passo 3, imagem 2 %32
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: passo 4, imagem 1 %32 Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: passo 4, imagem 2 %32 Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  5. Lenovo ThinkPad T490s SSD Replacement, Disconnect the battery cable: passo 5, imagem 1 %32 Lenovo ThinkPad T490s SSD Replacement, Disconnect the battery cable: passo 5, imagem 2 %32
    • Grab the battery pull-tab at the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD screw: passo 6, imagem 1 %32 Lenovo ThinkPad T490s SSD Replacement, Remove the SSD screw: passo 6, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the 3.7 mm-long screw holding down the SSD.
  7. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: passo 7, imagem 1 %32 Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: passo 7, imagem 2 %32 Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: passo 7, imagem 3 %32
    • Pull the SSD out and away from its socket.
    • If this motion requires excessive force, walk the SSD side to side as you pull.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
Clay Eickemeyer
Membro desde: 09/19/22
67.630 Reputação
Autoria de 453 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 137
Autoria de 17.457 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 76
Últimos 30 dias: 266
Duração total: 3,770
