Ir para o conteúdo principal
Lenovo ThinkPad T480s WWAN Card Replacement
O que você precisa
  1. Lenovo ThinkPad T480s WWAN Card Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo ThinkPad T480s WWAN Card Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s WWAN Card Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T480s WWAN Card Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T480s WWAN Card Replacement: passo 2, imagem 3 %32
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s WWAN Card Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T480s WWAN Card Replacement: passo 3, imagem 2 %32
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s WWAN Card Replacement, WWAN Card: passo 4, imagem 1 %32 Lenovo ThinkPad T480s WWAN Card Replacement, WWAN Card: passo 4, imagem 2 %32 Lenovo ThinkPad T480s WWAN Card Replacement, WWAN Card: passo 4, imagem 3 %32
    • Flip the cardboard cover off of the WWAN card.
    • Using the spudger, release the coaxial antenna wires from the WWAN card.
    • When reassembling, reattach the blue wire on the left and the orange wire on the right.
  5. Lenovo ThinkPad T480s WWAN Card Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T480s WWAN Card Replacement: passo 5, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove one 2.8mm screw.
  6. Lenovo ThinkPad T480s WWAN Card Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T480s WWAN Card Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T480s WWAN Card Replacement: passo 6, imagem 3 %32
    • Slide the WWAN card out from the slot.
Conclusão
Uma outra pessoa concluiu este guia.
Sarah Westberg
Membro desde: 03/11/19
23.278 Reputação
Autoria de 70 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.303 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 49
Últimos 30 dias: 147
Duração total: 3,271
