Ir para o conteúdo principal
Lenovo ThinkPad T480s SSD Replacement
O que você precisa
  1. Lenovo ThinkPad T480s SSD Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo ThinkPad T480s SSD Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s SSD Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T480s SSD Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T480s SSD Replacement: passo 2, imagem 3 %32
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s SSD Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T480s SSD Replacement: passo 3, imagem 2 %32
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s SSD Replacement, Battery: passo 4, imagem 1 %32 Lenovo ThinkPad T480s SSD Replacement, Battery: passo 4, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s SSD Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T480s SSD Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T480s SSD Replacement: passo 5, imagem 3 %32
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s SSD Replacement, SSD: passo 6, imagem 1 %32 Lenovo ThinkPad T480s SSD Replacement, SSD: passo 6, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove one 2.8 mm screw securing the SSD.
  7. Lenovo ThinkPad T480s SSD Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T480s SSD Replacement: passo 7, imagem 2 %32 Lenovo ThinkPad T480s SSD Replacement: passo 7, imagem 3 %32
    • Pull the SSD out of the socket.
Conclusão
Uma outra pessoa concluiu este guia.
Sarah Westberg
Membro desde: 03/11/19
35.163 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.752 guias
3Comentários do guia
Is there a need to remove the battery?
Sanjay - Responder
Hi Sanjay, we just want to make sure that there is no power to the system and the step to remove the battery is included as a precaution. Typically, you could detach the connector from the motherboard without removing the battery, and that would be sufficient. This connector is integrated into the battery case so we recommend battery removal. Thanks!
Sarah Westberg -
For ThinkPads, you can also disable the built-in battery in the BIOS settings before opening up the laptop. (You can always check if this is working by trying to turn on the laptop afterwards.) The internal battery stays off until you plug in the laptop with its wall charger again. This is shown in this video of the T480s (timestamped), before opening up the laptop.
Tai Lam -
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 113
Ao todo: 4,167
