Ir para o conteúdo principal
Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement
O que você precisa
  1. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 2, imagem 3 %32
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 3, imagem 2 %32
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Battery: passo 4, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Battery: passo 4, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 5, imagem 3 %32
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: passo 6, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: passo 6, imagem 2 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, Speaker: passo 6, imagem 3 %32
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 7, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 8, imagem 2 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 8, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 9, imagem 2 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 9, imagem 3 %32
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 10, imagem 2 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 10, imagem 3 %32
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
  11. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: passo 11, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: passo 11, imagem 2 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement, SD Card Reader/Audio Card: passo 11, imagem 3 %32
    • Use a spudger to lift up the retaining flap on the SD card reader/audio card connector.
  12. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 12, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 12, imagem 2 %32
    • Use the spudger to remove the cable from the connector.
    • The cable is attached to the board with adhesive so you will need to peel the cable up.
  13. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 13, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 13, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove two 3.1 mm screws from the card.
  14. Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 14, imagem 1 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 14, imagem 2 %32 Lenovo ThinkPad T480s SD Card Reader/Audio Card Replacement: passo 14, imagem 3 %32
    • Lift the SD card reader/audio card from the system by sliding it out from the socket.
    • You will need to slide the audio card ribbon cable under the coin cell battery cable to remove the SD card reader from the system.
Conclusão
Sarah Westberg
Membro desde: 03/11/19
23.372 Reputação
Autoria de 70 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.430 guias
Um comentário
It is not necessary to do steps 8 & 9.
K CHOI - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 63
Duração total: 1,525
