Ir para o conteúdo principal
Lenovo ThinkPad T480s Keyboard Replacement
O que você precisa
  1. Lenovo ThinkPad T480s Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Lenovo ThinkPad T480s Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Lenovo ThinkPad T480s Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Disable the battery, power down, and unplug your device before you begin.
    • Pry the left and right trackpad buttons up with a spudger.
  2. Lenovo ThinkPad T480s Keyboard Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T480s Keyboard Replacement: passo 2, imagem 2 %32
    • With a Phillips #0 screwdriver, loosen the two captive screws underneath the left and right trackpad buttons.
  3. Lenovo ThinkPad T480s Keyboard Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T480s Keyboard Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad T480s Keyboard Replacement: passo 3, imagem 3 %32
    • Wedge the spudger under the front edge of the keyboard to push the keyboard toward the back of the system.
    • Lift the front edge of the keyboard up by a few millimeters.
  4. Lenovo ThinkPad T480s Keyboard Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T480s Keyboard Replacement: passo 4, imagem 2 %32
    • Gently, pull the keyboard out from the bezel and flip it over.
    • It is connected to the keyboard and trackpad cables so be sure not to yank it over to avoid tearing them.
  5. Lenovo ThinkPad T480s Keyboard Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T480s Keyboard Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T480s Keyboard Replacement: passo 5, imagem 3 %32
    • Use the spudger to disconnect the trackpad cable from the system.
    • For more information on types of connectors, check out this guide.
  6. Lenovo ThinkPad T480s Keyboard Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T480s Keyboard Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T480s Keyboard Replacement: passo 6, imagem 3 %32
    • Use the spudger to disconnect the keyboard cable from the system.
  7. Lenovo ThinkPad T480s Keyboard Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T480s Keyboard Replacement: passo 7, imagem 2 %32
    • Lift the keyboard off of the palm rest.
Conclusão
4 outras pessoas executaram este guia.
Sarah Westberg
Membro desde: 03/11/19
29.489 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.539 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 73
Últimos 30 dias: 310
Ao todo: 8,993
