Ir para o conteúdo principal
Lenovo ThinkPad T480 Keyboard Replacement
O que você precisa
  1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement, External Battery: passo 1, imagem 2 %32
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Keyboard Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 2, imagem 3 %32
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
  4. Lenovo ThinkPad T480 Keyboard Replacement: passo 4, imagem 1 %32
    • Open the laptop so the keyboard is facing you.
  5. Lenovo ThinkPad T480 Keyboard Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 5, imagem 3 %32
    • Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
    • The keyboard is connected to the board by two ribbon connectors.
    • Be careful not to rip the connectors when you flip the keyboard over.
  6. Lenovo ThinkPad T480 Keyboard Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 6, imagem 3 %32
    • Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
    • Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
  7. Lenovo ThinkPad T480 Keyboard Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 7, imagem 2 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 7, imagem 3 %32
    • Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
  8. Lenovo ThinkPad T480 Keyboard Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad T480 Keyboard Replacement: passo 8, imagem 2 %32
    • Remove the keyboard from the laptop.
Conclusão
10 outras pessoas executaram este guia.
Sarah Westberg
Membro desde: 03/11/19
29.489 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.539 guias
3 comentários
Thanks for this. I need help with my Lenovo Thinkpad T480 keyboard to motherboard connector pin. That is the third image in step 6.
Where can I get a replacement?
EagleCreeks Assortment - Responder
Hi @lioneeddev99026, You are most welcome. I'm glad the guide was helpful!
Sarah Westberg -
Comentar
Exibir estatísticas:
Últimas 24 horas: 20
Últimos 7 dias: 124
Últimos 30 dias: 660
Ao todo: 18,073
