Ir para o conteúdo principal
Lenovo ThinkPad T480 Internal Battery Replacement
O que você precisa
  1. Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: passo 1, imagem 2 %32
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Internal Battery Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T480 Internal Battery Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T480 Internal Battery Replacement: passo 2, imagem 3 %32
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: passo 3, imagem 1 %32 Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Internal Battery Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T480 Internal Battery Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad T480 Internal Battery Replacement: passo 4, imagem 3 %32
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: passo 5, imagem 1 %32 Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: passo 5, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
  6. Lenovo ThinkPad T480 Internal Battery Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T480 Internal Battery Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T480 Internal Battery Replacement: passo 6, imagem 3 %32
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Internal Battery Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T480 Internal Battery Replacement: passo 7, imagem 2 %32 Lenovo ThinkPad T480 Internal Battery Replacement: passo 7, imagem 3 %32
    • Using the black nylon spudger, wedge the battery up from the case and lift it out.
Conclusão
7 outras pessoas executaram este guia.
Sarah Westberg
Membro desde: 03/11/19
23.227 Reputação
Autoria de 70 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.199 guias
4 comentários
"What you need" contains a wrong part.
cumledomla - Responder
Hi @cumledomla, I've added the internal battery for this guide. Thanks for pointing that out! The external battery will show up in the "What you need" section because it's imported from the prerequisite guide for the external battery. Hope this helps.
Sarah Westberg - Responder
The "Battery 2" on my T480 does not load. Is Battery 2 the internal or the external battery?
Finn Hove - Responder
Battery 2 is the external battery.
Peter Falk - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 32
Últimos 7 dias: 248
Últimos 30 dias: 1,105
Duração total: 33,833
