Ir para o conteúdo principal
Lenovo ThinkPad T470 Wi-Fi Card Replacement
O que você precisa
  1. Lenovo ThinkPad T470 Wi-Fi Card Replacement, External Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T470 Wi-Fi Card Replacement, External Battery: passo 1, imagem 2 %32 Lenovo ThinkPad T470 Wi-Fi Card Replacement, External Battery: passo 1, imagem 3 %32
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 2, imagem 3 %32
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Wi-Fi Card Replacement, Bottom Cover: passo 3, imagem 1 %32 Lenovo ThinkPad T470 Wi-Fi Card Replacement, Bottom Cover: passo 3, imagem 2 %32
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 4, imagem 3 %32
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 5, imagem 1 %32
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 Wi-Fi Card Replacement, Wi-Fi Card: passo 6, imagem 1 %32 Lenovo ThinkPad T470 Wi-Fi Card Replacement, Wi-Fi Card: passo 6, imagem 2 %32
    • Use a finger to press the black flap covering the Wi-Fi card down.
  7. Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 7, imagem 2 %32
    • Use the flat end of a spudger to disconnect the two coaxial wires from the Wi-Fi card.
    • When reassembling, reattach the gray wire on the left and the black wire on the right.
  8. Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 8, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw from the Wi-Fi card.
  9. Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad T470 Wi-Fi Card Replacement: passo 9, imagem 2 %32
    • Use your fingers to lift the Wi-Fi card up and out of its slot.
    • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 6-9 to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Kristen Gismondi
Membro desde: 11/12/14
84.850 Reputação
Autoria de 215 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 76
Duração total: 2,322
