Introdução
This guide explains how to replace the battery in a Lenovo ThinkPad T430s. The battery allows your ThinkPad to run when not plugged into a power source.
Your battery may need replacement if it won’t power on unless connected to a power source. Also, if your ThinkPad abruptly stops running when disconnected from a power source, the battery may be dead. Click this link to access the troubleshooting page and determine if your battery needs replacement.
O que você precisa
Flip your ThinkPad on its back.
In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
Use your other hand to lift the battery up by prying the notch to the left of the lever.
Tilt the battery up and remove it from the ThinkPad.
Um comentário
Does anybody have recommendations on where to get a good battery in North America? All I can find is shovelware batteries...
