Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Lenovo ThinkPad T410s Palm-rest Replacement
O que você precisa
  1. Lenovo ThinkPad T410s Palm-rest Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over.
    • Push and hold the locking switch to the left.
    • Pull the battery out with your other hand.
  2. Lenovo ThinkPad T410s Palm-rest Replacement, RAM: passo 2, imagem 1 %32 Lenovo ThinkPad T410s Palm-rest Replacement, RAM: passo 2, imagem 2 %32
    • Remove the single Phillips #0 screw grin the back panel.
    • Pull the back panel off.
  3. Lenovo ThinkPad T410s Palm-rest Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T410s Palm-rest Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad T410s Palm-rest Replacement: passo 3, imagem 3 %32
    • Pull the metal prongs at the side of the RAM away from each other.
    • The RAM will pop out of its socket when done correctly.
    • Pull the RAM out.
  4. Lenovo ThinkPad T410s Palm-rest Replacement, Keyboard: passo 4, imagem 1 %32
    • Remove the Flathead 2.5mm screw.
  5. Lenovo ThinkPad T410s Palm-rest Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T410s Palm-rest Replacement: passo 5, imagem 2 %32
    • Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
  6. Lenovo ThinkPad T410s Palm-rest Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T410s Palm-rest Replacement: passo 6, imagem 2 %32
    • Slide the keyboard out of the way until you can see what's underneath it.
    • The keyboard is still attached with a ribbon cable so don't try to fully remove it.
  7. Lenovo ThinkPad T410s Palm-rest Replacement: passo 7, imagem 1 %32
    • Use the flat end of a spudger to unplug the keyboard connector from the laptop.
    • Pull the keyboard out.
  8. Lenovo ThinkPad T410s Palm-rest Replacement, Palm-rest: passo 8, imagem 1 %32
    • Remove the twelve Phillips #0 screws from the back panel.
  9. Lenovo ThinkPad T410s Palm-rest Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad T410s Palm-rest Replacement: passo 9, imagem 2 %32
    • Up the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull out the ribbon connector from the ZIF connector.
  10. Lenovo ThinkPad T410s Palm-rest Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad T410s Palm-rest Replacement: passo 10, imagem 2 %32
    • Remove the palm rest from the laptop.
Conclusão
Nathan Barganier
Membro desde: 02/21/18
97 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 1,420
