Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the laptop over.
Push and hold the locking switch to the left.
Pull the battery out with your other hand.
Remove the single Phillips #0 screw grin the back panel.
Pull the back panel off.
Pull the metal prongs at the side of the RAM away from each other.
Pull the RAM out.
Remove the Flathead 2.5mm screw.
Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
Slide the keyboard out of the way until you can see what's underneath it.
Use the flat end of a spudger to unplug the keyboard connector from the laptop.
Pull the keyboard out.
Remove the twelve Phillips #0 screws from the back panel.
Up the flat end of a spudger to lift up the black tab on the ZIF connector.
Pull out the ribbon connector from the ZIF connector.
