Introdução
If you have to forcefully press the power button multiple times to get your screen to come on, follow these simple steps to replace the power button.
O que você precisa
Gently insert a spudger into one of the bottom corners between the screen and body case. Gently slide the spudger along the inside of the crack to pry the case open
