Ir para o conteúdo principal
Lenovo Tab 4 TB-8504F Vibrator Replacement
O que você precisa
  1. Lenovo Tab 4 TB-8504F Vibrator Replacement, Battery: passo 1, imagem 1 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement, Battery: passo 1, imagem 2 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement, Battery: passo 1, imagem 3 %32
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 2, imagem 1 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 2, imagem 2 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 3, imagem 1 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 3, imagem 2 %32
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 4, imagem 1 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 4, imagem 2 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 4, imagem 3 %32
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
  5. Lenovo Tab 4 TB-8504F Vibrator Replacement, Vibrator: passo 5, imagem 1 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement, Vibrator: passo 5, imagem 2 %32
    • Remove 16 screws from the midframe with Phillips #000 screwdriver [bit].
  6. Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 6, imagem 1 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 6, imagem 2 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 6, imagem 3 %32
    • Using an opening pick, find a spot to lift the bracket around the tablet.
    • When the opening pick is inserted between the bracket and tablet, move the pick around the whole tablet to completely detach the bracket.
  7. Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 7, imagem 1 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 7, imagem 2 %32 Lenovo Tab 4 TB-8504F Vibrator Replacement: passo 7, imagem 3 %32
    • Using the soldering iron can be very dangerous if not used carefully. Solder iron is very hot.
    • Desolder the blue and red wires from the motherboard.
    • Once wires are detached, use a metal spudger tool to lift the vibrator.
    • If the wire is not detaching from the tin, raise the heat on the soldering iron.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 791
