O que você precisa
Start at the microSD slot.
Use the opening pick to slide underneath the back cover of the tablet.
Slide the opening pick around the tablet until the back cover is off.
There is a yellow tape holding the microSD card reader connector. Use tweezers to hold down the tape.
Gently lift the tab on the microSD card reader's ZIF connector, and gently pull the ribbon cable free.
Use a spudger to lift the rear camera press-fit connector up and free.
Use tweezers to lift the rear camera out of the frame.
Using tweezers, lift the yellow tape hiding the front camera.
Disconnect the front camera's connector from the motherboard using tweezers.
Use tweezers to pull screen digitizer cable from the motherboard.
3 outras pessoas executaram este guia.
