Introdução
This guide explains how to remove the rear facing camera from the Miix 2 for an easy replacement.
O que você precisa
Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
Locate the LCD cable connector and gently pry it directly up with a spudger.
Free the rubber housing around the camera by gently prying up with the spudger.
Remove the rubber housing from the camera with tweezers.
