Ir para o conteúdo principal
Lenovo Legion Y530-15ICH Motherboard Replacement
O que você precisa
  1. Lenovo Legion Y530-15ICH Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 2, imagem 1 %32 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 2, imagem 2 %32
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Motherboard Replacement, Battery: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
  4. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 4, imagem 1 %32 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 4, imagem 2 %32
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Now you can safely remove the battery.
    Hello IFixit people!
    I ran into an issue after cleaning out the fans and installing an m.2 SSD in my friend's . After the installation I replaced the back cover and tried to boot the machine. When I plugged in the charger cable the charging indicator light wouldn't boot. I went through all the troubleshooting info on Lenovo and Ifixit and even tested the power supply with no definitive fault. Now i've found a Hotspot on the mobo when the laptop is powered off. Just above the battery to the right of the battery plug are a cluster of capacitors or transistors or something that sit at about 130°C when the laptop is powered off. Any ideas for troubleshooting or advice for a fix would be appreciated!
    The board component in question is labeled 1R5910CTS
    cheesehead 1010 - Responder
  5. Lenovo Legion Y530-15ICH Motherboard Replacement, Fan: passo 5, imagem 1 %32 Lenovo Legion Y530-15ICH Motherboard Replacement, Fan: passo 5, imagem 2 %32
    • Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
    • Remove the plastic covering after the screws have been loosened.
    • Spring screws will stay attached to the cover.
    There were 6 holding the heat sink on when I did it.
    Bryce Christensen - Responder
  6. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 6, imagem 1 %32
    • Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
  7. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 7, imagem 1 %32
    • Unplug the wires connecting the two fans to the motherboard.
    • When doing this, tug carefully from side to side.
  8. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 8, imagem 1 %32 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 8, imagem 2 %32
    • Lift the fans out of their positions and remove them from the device.
    Don't forget to pick up thermal paste so you get a good contact between the CPU and GPU and the heat sinks!
  9. Lenovo Legion Y530-15ICH Motherboard Replacement, Solid State Drive: passo 9, imagem 1 %32 Lenovo Legion Y530-15ICH Motherboard Replacement, Solid State Drive: passo 9, imagem 2 %32
    • Do not remove the thermal pad.
    • Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
  10. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 10, imagem 1 %32 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 10, imagem 2 %32
    • Carefully remove the SSD from its connector.
  11. Lenovo Legion Y530-15ICH Motherboard Replacement, Motherboard: passo 11, imagem 1 %32 Lenovo Legion Y530-15ICH Motherboard Replacement, Motherboard: passo 11, imagem 2 %32
    • Start by disconnecting the ribbon cable that is near the audio driver. It is recommended to use the iFixit Opening Pick to remove the ribbon cable.
  12. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 12, imagem 1 %32 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 12, imagem 2 %32
    • Remove three 4mm screws using a JIS #1 screwdriver.
    • Remove the black cover the screws were holding down.
  13. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 13, imagem 1 %32 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 13, imagem 2 %32
    • Remove the 4mm screw on top of the audio driver using a JIS #1 screwdriver.
    • Pull the audio cables gently off the audio driver.
    • Remove the audio driver from the motherboard.
  14. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 14, imagem 1 %32
    • Remove twelve 4mm screws circled in red using a JIS #1 screwdriver.
    • Peel off the Lenovo sticker and remove one 4mm screw with a JIS #1 screwdriver.
  15. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 15, imagem 1 %32
    • Remove two ribbon cables in the circled areas. Gently pull them out of their ports.
  16. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 16, imagem 1 %32
    • Remove the final ribbon cable by gently pulling it from its socket.
    • The motherboard is now completely disconnected from the laptop.
  17. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 17, imagem 1 %32 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 17, imagem 2 %32
    • Gently lift the motherboard out of the housing.
    Where can I get a new motherboard?
    ساره سعيد - Responder
Conclusão
4 outras pessoas executaram este guia.
Kaylie Klausing
Membro desde: 02/07/20
776 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S7-G1, Regan Winter 2020 Membro de Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
4 Membros
Autoria de 12 guias
3Comentários do guia
Kaylie Klausing
I hope you burn in !&&*
Safwat Ali - Responder
You fckking piece of $@$*.
DON'T FOLLOW THIS.
FCKKKK YOUUUUU
What the hell is wrong with this guy?
Safwat Ali is a real jerk - Responder
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 29
Últimos 30 dias: 102
Ao todo: 9,210
