Introdução
Use this guide to remove or replace the back cover on a Lenovo Legion 5 Pro 16ACH6H laptop.
Before you perform this repair, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
O que você precisa
Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
Six 12.7 mm PH00 screws
Four 4.2 mm PH00 screws
Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
Insert the rounded edge of an opening pick between the back cover and the frame on the right edge.
Angle the pick to about 30˚ and slide down the right edge until you reach the plastic vents on the side.
Repeat the same procedure on the left edge to release the clips.
Position the laptop vertically so you can easily access the plastic vents.
Slide the rounded edge of an opening pick between the frame and the plastic vents on the right side near the USB-A port.
Rotate the pick so that it is positioned on top of the plastic vents.
Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
5 outras pessoas executaram este guia.
3 comentários
Wish I read this guide before I did mine, got it done with a lot more hassle. Would love to see advice on what to use if you don't have an opening pick (a guy on YT had a guitar pick, I just used an old credit card and it was very difficult).
