Ir para o conteúdo principal
Lenovo Legion 5 17ACH6H Left SSD Replacement
O que você precisa
  1. Lenovo Legion 5 17ACH6H Left SSD Replacement, Back cover removal: passo 1, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Back cover removal: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the following ten screws securing the back cover to the frame:
    • Six 12.8 mm PH1 screws
    • Four 4.6 mm PH1 screws
  2. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the front clips: passo 2, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the front clips: passo 2, imagem 2 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the front clips: passo 2, imagem 3 %32
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
    • Angle the pick to about 45˚.
  3. Lenovo Legion 5 17ACH6H Left SSD Replacement: passo 3, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement: passo 3, imagem 2 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement: passo 3, imagem 3 %32
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right clips: passo 4, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right clips: passo 4, imagem 2 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right clips: passo 4, imagem 3 %32
    • Insert the edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the left edge to release the clips.
  5. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left clips: passo 5, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left clips: passo 5, imagem 2 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left clips: passo 5, imagem 3 %32
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right vent clips: passo 6, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right vent clips: passo 6, imagem 2 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right vent clips: passo 6, imagem 3 %32
    • Slide the opening pick between the frame and the plastic vents on the right side near the USB-A port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
    • If the pick is difficult to insert, position the laptop vertically to reduce the weight on the back cover.
  7. Lenovo Legion 5 17ACH6H Left SSD Replacement: passo 7, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement: passo 7, imagem 2 %32
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left vent clips: passo 8, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left vent clips: passo 8, imagem 2 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left vent clips: passo 8, imagem 3 %32
    • Slide the opening pick between the frame and the plastic vents on the left side near the USB-C port.
  9. Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the back cover: passo 9, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the back cover: passo 9, imagem 2 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the back cover: passo 9, imagem 3 %32
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  10. Lenovo Legion 5 17ACH6H Left SSD Replacement, Disconnect the battery: passo 10, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Disconnect the battery: passo 10, imagem 2 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Disconnect the battery: passo 10, imagem 3 %32
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  11. Lenovo Legion 5 17ACH6H Left SSD Replacement: passo 11, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement: passo 11, imagem 2 %32
    • Use the flat end of a spudger to push out and disconnect battery cable.
  12. Lenovo Legion 5 17ACH6H Left SSD Replacement, Left SSD removal: passo 12, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Left SSD removal: passo 12, imagem 2 %32
    • Use a Phillips screwdriver to remove the four screws securing the left SSD shield to the motherboard:
    • Three 3.3 mm PH1 screws.
    • One 5 mm PH00 screw.
    • During reassembly, make sure the two holes on the left side of the shield align with the posts on the chassis.
  13. Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the SSD shield: passo 13, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the SSD shield: passo 13, imagem 2 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the SSD shield: passo 13, imagem 3 %32
    • Grab the SSD shield and lift up to remove it.
  14. Lenovo Legion 5 17ACH6H Left SSD Replacement: passo 14, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement: passo 14, imagem 2 %32
    • Use a Phillips screwdriver to remove the 2.8 mm PH1 screw securing the SSD to the motherboard.
    • The SSD will spring up to about 30˚ when the screw is removed.
  15. Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the left SSD: passo 15, imagem 1 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the left SSD: passo 15, imagem 2 %32 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the left SSD: passo 15, imagem 3 %32
    • Grip the edges of the SSD near the screw indent.
    • Gently pull to remove the SSD.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion Answers community for help.
Chayton Ritter
Membro desde: 08/21/20
22.518 Reputação
Autoria de 105 guias
Equipe
Guide Team Membro de Guide Team
Staff
9 Membros
Autoria de 11.420 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 87
Ao todo: 3,683
