Ir para o conteúdo principal
Lenovo Ideapad 320-17IKB Battery Replacement
O que você precisa
  1. Lenovo Ideapad 320-17IKB Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Battery Replacement: passo 2, imagem 1 %32 Lenovo Ideapad 320-17IKB Battery Replacement: passo 2, imagem 2 %32
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Battery Replacement: passo 3, imagem 1 %32
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Battery Replacement: passo 4, imagem 1 %32 Lenovo Ideapad 320-17IKB Battery Replacement: passo 4, imagem 2 %32
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Battery Replacement, Battery: passo 5, imagem 1 %32 Lenovo Ideapad 320-17IKB Battery Replacement, Battery: passo 5, imagem 2 %32
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Battery Replacement: passo 6, imagem 1 %32 Lenovo Ideapad 320-17IKB Battery Replacement: passo 6, imagem 2 %32
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 18
Duração total: 4,328
