Ir para o conteúdo principal
Lenovo IdeaPad G50-45 DVD Drive Replacement
O que você precisa
  1. Lenovo IdeaPad G50-45 DVD Drive Replacement, DVD Drive: passo 1, imagem 1 %32
    • First, remove the three screws located on the bottom panel of the laptop using a Philips #2 screwdriver.
    • To avoid losing the small screws, put them in a container.
  2. Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 2, imagem 2 %32
    • To remove the panel on the laptop, gently slide the panel away from the battery.
    • Make sure to slide the panel away before you lift to keep the panel from breaking.
    • Lift up the panel and place it to the side.
  3. Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 3, imagem 2 %32
    • Remove the indicated screw holding the DVD Drive.
    • To avoid losing the screw, place it in the same container used to hold the other three screws.
  4. Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 4, imagem 1 %32
    • Push the now-free tab towards the DVD Drive using a flathead screwdriver.
    • Do not pry up the now-free tab.
  5. Lenovo IdeaPad G50-45 DVD Drive Replacement: passo 5, imagem 1 %32
    • Lastly, pull out the DVD Drive; it should come out easily.
Conclusão
6 outras pessoas executaram este guia.
Saulo Gomes
Membro desde: 10/26/15
601 Reputação
2 Guias de autoria
Equipe
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Membro de UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Membros
5 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 33
Duração total: 8,298
