Introdução
After reading this guide you should be able to replace the battery in a Lenovo IdeaPad G50-45. Make sure to read the troubleshooting page for this device before hand so you know that this is the correct repair guide for your problem.
O que você precisa
Safely place the Device upside down and have the battery component facing yourself.
To reassemble your device, follow these instructions in reverse order, and make sure to hold the left switch to the left when inserting the new battery.
3 outras pessoas executaram este guia.
