Ir para o conteúdo principal
Lenovo IdeaPad Flex 5-1570 USB Port Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 2, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 2, imagem 3 %32
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 3, imagem 2 %32
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Fan: passo 4, imagem 1 %32
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  5. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 5, imagem 1 %32
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  6. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 6, imagem 2 %32
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  7. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Battery: passo 7, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Battery: passo 7, imagem 2 %32
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  8. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 8, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 8, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 8, imagem 3 %32
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  9. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: passo 9, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: passo 9, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: passo 9, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  10. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 10, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 10, imagem 2 %32
    • Using your hands, gently pull the left speaker up and out of the device.
  11. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 11, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 11, imagem 2 %32
    • Repeat the previous step for the other speaker and remove the speakers from the device.
  12. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Motherboard: passo 12, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the three 5 mm Phillips #00 screws securing the motherboard.
  13. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 13, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 13, imagem 2 %32
    • Disconnect the auxiliary port cable from the motherboard.
  14. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 14, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 14, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 14, imagem 3 %32
    • Using a plastic opening tool, unlock the four ZIF connectors of the flat cables.
    • Lift up the connector locking tab and disconnect the cables from the motherboard.
  15. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 15, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 15, imagem 2 %32
    • Disconnect the display cable from the motherboard.
  16. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 16, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 16, imagem 2 %32
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  17. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 17, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: passo 17, imagem 2 %32
    • Carefully lift and remove the motherboard from the device.
  18. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, USB Port: passo 18, imagem 1 %32
    • Once you've removed the motherboard, desolder the four contact points on the USB connector.
    • For proper technique on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the USB port from the device.
    • Resolder the new USB connector in the same place.
Conclusão
Uma outra pessoa concluiu este guia.
Nate Blake
Membro desde: 01/23/20
507 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S2-G6, White Winter 2020 Membro de Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
Membros da 4
Autoria de 13 guias
2 comentários
what is the replacement part number?
Edwin Maynard - Responder
Was anyone able to find a part number for the specific USB ports?
Greg - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 32
Duração total: 2,923
