Ir para o conteúdo principal
Lenovo IdeaPad 3-15IIL05 SSD Replacement
O que você precisa
  1. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Prepare your laptop for disassembly: passo 1, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Prepare your laptop for disassembly: passo 1, imagem 2 %32
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the back cover: passo 2, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the back cover: passo 2, imagem 2 %32
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  3. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: passo 3, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: passo 3, imagem 2 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: passo 3, imagem 3 %32
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  4. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the left clips: passo 4, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the left clips: passo 4, imagem 2 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the left clips: passo 4, imagem 3 %32
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  5. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the bottom clips: passo 5, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the bottom clips: passo 5, imagem 2 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the bottom clips: passo 5, imagem 3 %32
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  6. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the right clips: passo 6, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the right clips: passo 6, imagem 2 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the right clips: passo 6, imagem 3 %32
    • Slide the opening pick to the top right corner to release the right clips.
  7. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: passo 7, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: passo 7, imagem 2 %32
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  8. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the top clips: passo 8, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the top clips: passo 8, imagem 2 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the top clips: passo 8, imagem 3 %32
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  9. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the back cover: passo 9, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the back cover: passo 9, imagem 2 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the back cover: passo 9, imagem 3 %32
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  10. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Disconnect the battery: passo 10, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Disconnect the battery: passo 10, imagem 2 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Disconnect the battery: passo 10, imagem 3 %32
    • Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
  11. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the thermal pad: passo 11, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the thermal pad: passo 11, imagem 2 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the thermal pad: passo 11, imagem 3 %32
    • A delicate thermal pad covers the SSD. If you're planning on reusing it, be extra careful during this step.
    • Gently lift the left edge of the thermal pad.
    • Carefully slide the flat end of a spudger back and forth under the pad while slowly peeling the pad back.
    • Remove the thermal pad.
    • Set the thermal pad aside and apply it to the new SSD during reassembly.
    • If you tore the thermal pad when taking it off, don’t worry—you can still reuse it.
  12. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the SSD: passo 12, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the SSD: passo 12, imagem 2 %32
    • Use a Phillips screwdriver to remove the 3 mm-long screw securing the SSD.
    • The SSD will pop up at a slight angle with the screw removed.
  13. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the SSD: passo 13, imagem 1 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the SSD: passo 13, imagem 2 %32 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the SSD: passo 13, imagem 3 %32
    • Pull the SSD out of its socket and remove it.
    • During reassembly, insert the SSD at a slight downward angle into its socket.
Conclusão
Check your repair by running hardware tests with Lenovo Diagnostics.
Spencer Day
Membro desde: 09/14/22
61.613 Reputação
Autoria de 445 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.085 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 92
Últimos 30 dias: 352
Duração total: 2,422
