Introdução
Use this guide to remove the battery from the Lenovo IdeaPad 130-15AST. The battery is a hardware component in the laptop which supplies power to the whole laptop. The battery will need to be replaced if you have confirmed that the battery cannot hold any power or charge. Reference the Troubleshooting Page to confirm your battery isn’t charging. Follow the steps in the Replacement Guide carefully to remove the Battery safely and efficiently.
O que você precisa
Using a Phillips #00 screwdriver, remove one of the 6.0mm screws.
4 outras pessoas executaram este guia.
