Ir para o conteúdo principal
Lenovo IdeaPad 120s-14IAP Battery Replacement
O que você precisa
  1. Lenovo IdeaPad 120s-14IAP Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo IdeaPad 120s-14IAP Battery Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo IdeaPad 120s-14IAP Battery Replacement, Battery: passo 3, imagem 1 %32
    • Remove five 1.5mm Phillips screws from the battery edges.
  4. Lenovo IdeaPad 120s-14IAP Battery Replacement: passo 4, imagem 1 %32
    • Use your fingers or a spudger to unlock the wide ribbon cable's ZIF connector.
    • To unlock a ZIF connector, flip up the small, hinged locking flap.
    • Gently pull the connector from the battery side until it is fully detached from the daughterboard.
  5. Lenovo IdeaPad 120s-14IAP Battery Replacement: passo 5, imagem 1 %32
    • Gently pull the power harness away from the daughterboard until the connector is detached.
    • Pull parallel to the board, not straight up.
  6. Lenovo IdeaPad 120s-14IAP Battery Replacement: passo 6, imagem 1 %32
    • With the laptop oriented so that the long edge faces you and the battery is closest to you, carefully remove the battery by lifting on the longitudinal edge.
    • Pull the battery directly towards you and out from under the forward retaining strap.
Conclusão
Uma outra pessoa concluiu este guia.
2 comentários
Thank you for showing exactly how to remove the battery connections, thanks!
Erik Gunnar Gervin - Responder
Great guide. I may well need a new battery but would appreciate your comment. Battery shows charging but never gets above 0%
When I put a meter at the 2 red cables they show zero volts (even when computer on, and showing charging). Other wires are ~1.6v & 3.4v.
Could I have a faulty battery or something else?
Colin Kinsella - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 47
Duração total: 5,186
