Ir para o conteúdo principal
Lenovo Essential G570 RAM Replacement
O que você precisa
  1. Lenovo Essential G570 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
    Pergunte ao FixBot
    Comentar
  2. Lenovo Essential G570 RAM Replacement: passo 2, imagem 1 %32 Lenovo Essential G570 RAM Replacement: passo 2, imagem 2 %32
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
    Pergunte ao FixBot
    Comentar
  3. Lenovo Essential G570 RAM Replacement: passo 3, imagem 1 %32 Lenovo Essential G570 RAM Replacement: passo 3, imagem 2 %32
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
    Pergunte ao FixBot
    Comentar
  4. Lenovo Essential G570 RAM Replacement, Back Panel: passo 4, imagem 1 %32
    • Turn the laptop over so that the bottom side is facing up.
    Pergunte ao FixBot
    Comentar
  5. Lenovo Essential G570 RAM Replacement: passo 5, imagem 1 %32
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
    Pergunte ao FixBot
    Comentar
  6. Lenovo Essential G570 RAM Replacement: passo 6, imagem 1 %32 Lenovo Essential G570 RAM Replacement: passo 6, imagem 2 %32 Lenovo Essential G570 RAM Replacement: passo 6, imagem 3 %32
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
    Pergunte ao FixBot
    Comentar
  7. Lenovo Essential G570 RAM Replacement, RAM: passo 7, imagem 1 %32
    • Using your fingers, hold open the two clips holding the top RAM in place.
    • The two RAM chips are placed one on top of another. It is important to take the top one out first to easily access the bottom one.
    • With the clips held away from the RAM, slide the top stick out from it's connection.
    Pergunte ao FixBot
    Comentar
  8. Lenovo Essential G570 RAM Replacement: passo 8, imagem 1 %32
    • With the top RAM stick removed, repeat the same process for the bottom piece. Begin by holding the two clips away from the RAM.
    • With the clips held out, slide the RAM out from the connection.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Justin Bickford
Membro desde: 03/01/18
479 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 1,096
