Ir para o conteúdo principal
Lenovo Essential G570 Keyboard Replacement
O que você precisa
  1. Lenovo Essential G570 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
    Pergunte ao FixBot
    Comentar
  2. Lenovo Essential G570 Keyboard Replacement: passo 2, imagem 1 %32 Lenovo Essential G570 Keyboard Replacement: passo 2, imagem 2 %32
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
    Pergunte ao FixBot
    Comentar
  3. Lenovo Essential G570 Keyboard Replacement: passo 3, imagem 1 %32 Lenovo Essential G570 Keyboard Replacement: passo 3, imagem 2 %32
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
    Pergunte ao FixBot
    Comentar
  4. Lenovo Essential G570 Keyboard Replacement, Back Panel: passo 4, imagem 1 %32
    • Turn the laptop over so that the bottom side is facing up.
    Pergunte ao FixBot
    Comentar
  5. Lenovo Essential G570 Keyboard Replacement: passo 5, imagem 1 %32
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
    Pergunte ao FixBot
    Comentar
  6. Lenovo Essential G570 Keyboard Replacement: passo 6, imagem 1 %32 Lenovo Essential G570 Keyboard Replacement: passo 6, imagem 2 %32 Lenovo Essential G570 Keyboard Replacement: passo 6, imagem 3 %32
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
    Pergunte ao FixBot
    Comentar
  7. Lenovo Essential G570 Keyboard Replacement, Keyboard: passo 7, imagem 1 %32
    • Remove the two 9mm Phillips #0 screws.
    • Remove the single 5mm Phillips #0 screw.
    • All 3 screws are located next to keyboard icons.
    Pergunte ao FixBot
    Comentar
  8. Lenovo Essential G570 Keyboard Replacement: passo 8, imagem 1 %32 Lenovo Essential G570 Keyboard Replacement: passo 8, imagem 2 %32
    • Flip the computer over and open it.
    • Using the plastic opening tool, pry open the top of the keyboard.
    Pergunte ao FixBot
    Comentar
  9. Lenovo Essential G570 Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the keyboard by gently pulling the top of the keyboard loose, and then lifting the keyboard out.
    • Be careful lifting the keyboard up because there is a delicate ribbon cable connected to the bottom.
    Pergunte ao FixBot
    Comentar
  10. Lenovo Essential G570 Keyboard Replacement: passo 10, imagem 1 %32 Lenovo Essential G570 Keyboard Replacement: passo 10, imagem 2 %32 Lenovo Essential G570 Keyboard Replacement: passo 10, imagem 3 %32
    • While lifting the keyboard, push the black latch on the keyboard cable ZIF connector forward to unlock it.
    • Carefully pull away the ribbon cable to detach it from the motherboard.
    • Be careful when unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Nina Francisco
Membro desde: 03/01/18
412 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 41
Ao todo: 3,129
