Ir para o conteúdo principal
Lenovo Essential G560 Keyboard Replacement
O que você precisa
  1. Lenovo Essential G560 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
    Pergunte ao FixBot
    Comentar
  2. Lenovo Essential G560 Keyboard Replacement: passo 2, imagem 1 %32 Lenovo Essential G560 Keyboard Replacement: passo 2, imagem 2 %32
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
    Pergunte ao FixBot
    Comentar
  3. Lenovo Essential G560 Keyboard Replacement: passo 3, imagem 1 %32
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
    Pergunte ao FixBot
    Comentar
  4. Lenovo Essential G560 Keyboard Replacement, Back Panel: passo 4, imagem 1 %32
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
    Pergunte ao FixBot
    Comentar
  5. Lenovo Essential G560 Keyboard Replacement: passo 5, imagem 1 %32 Lenovo Essential G560 Keyboard Replacement: passo 5, imagem 2 %32
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
    Pergunte ao FixBot
    Comentar
  6. Lenovo Essential G560 Keyboard Replacement: passo 6, imagem 1 %32
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
    Pergunte ao FixBot
    Comentar
  7. Lenovo Essential G560 Keyboard Replacement, Keyboard: passo 7, imagem 1 %32
    • Remove the two 5.3 mm Phillips #1 screws from the underside of the laptop computer.
    • Remove the 4.4 mm Phillips #1 screw located next to the Fan Assembly.
    Pergunte ao FixBot
    Comentar
  8. Lenovo Essential G560 Keyboard Replacement: passo 8, imagem 1 %32
    • Flip the computer over.
    • Using the plastic opening tool, push in the four small, plastic tabs located at the top of the keyboard.
    Pergunte ao FixBot
    Comentar
  9. Lenovo Essential G560 Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the keyboard by gently pulling the top loose, and then lifting the keyboard out.
    • While this step can be accomplished using your hand, it may be easier to use a spudger or plastic opening tool.
    Pergunte ao FixBot
    Comentar
  10. Lenovo Essential G560 Keyboard Replacement: passo 10, imagem 1 %32
    • Lift the keyboard up from the bezel.
    • Push the gray latch on the keyboard cable ZIF connector forward to unlock it.
    • Carefully pull the keyboard cable from its socket.
    • Be very careful while unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
    Pergunte ao FixBot
    Comentar
Conclusão
13 outras pessoas executaram este guia.
Dennis Wong
Membro desde: 01/11/13
618 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 18-40, Regan Winter 2013 Membro de Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Membros
Autoria de 13 guias
2Comentários do guia
Thank you frndzz
Anand krishnan - Responder Compartilhar
Thank you frndz
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 56
Ao todo: 19,540
