Ir para o conteúdo principal
Lenovo Essential B570 RAM Replacement
O que você precisa
  1. Lenovo Essential B570 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn over laptop.
    • Switch open the left battery lock.
    • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
    Pergunte ao FixBot
    Comentar
  2. Lenovo Essential B570 RAM Replacement: passo 2, imagem 1 %32
    • Hold the right battery lock open with one hand while removing the battery itself with the other.
    Pergunte ao FixBot
    Comentar
  3. Lenovo Essential B570 RAM Replacement, Back Panel: passo 3, imagem 1 %32
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
    Pergunte ao FixBot
    Comentar
  4. Lenovo Essential B570 RAM Replacement: passo 4, imagem 1 %32 Lenovo Essential B570 RAM Replacement: passo 4, imagem 2 %32 Lenovo Essential B570 RAM Replacement: passo 4, imagem 3 %32
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
    Pergunte ao FixBot
    Comentar
  5. Lenovo Essential B570 RAM Replacement, RAM: passo 5, imagem 1 %32 Lenovo Essential B570 RAM Replacement, RAM: passo 5, imagem 2 %32
    • Release your RAM by pulling its locks away from one another.
    Pergunte ao FixBot
    Comentar
  6. Lenovo Essential B570 RAM Replacement: passo 6, imagem 1 %32 Lenovo Essential B570 RAM Replacement: passo 6, imagem 2 %32
    • Remove RAM by carefully pulling it away from its socket.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 4-5, Catania Fall 2015 Membro de UMass Dartmouth, Team 4-5, Catania Fall 2015
UMASSD-CATANIA-F15S4G5
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 1,281
