Introdução
This guide will give you a step-by-step process for replacing the battery on the Lenovo Edge 15 laptop. You will need to remove the back-cover first. Caution: If battery is leaking do not touch it with your hands.
O que você precisa
Locate the eleven M2 x 6.0mm back-cover screws.
Unscrew the screws using the Phillips #0 screwdriver.
5 outras pessoas executaram este guia.
3Comentários do guia
Can I recharge a fully drained battery by reseating it?
My laptop caught on fire don't recommend
talvez alguien sabe donde puedo conseguir esta bateria o en que precio puede estar.
