Ir para o conteúdo principal
Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement
O que você precisa
  1. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 2, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 2, imagem 2 %32
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 3, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 3, imagem 2 %32
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Battery: passo 4, imagem 1 %32
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 5, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 5, imagem 2 %32
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 6, imagem 1 %32
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Wi-Fi Card: passo 7, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Wi-Fi Card: passo 7, imagem 2 %32
    • Remove the single 2 mm screw from the Wi-Fi card using a Phillips #00 screwdriver.
  8. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 8, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 8, imagem 2 %32
    • Detach the Wi-Fi card from the motherboard using an iFixit opening tool.
  9. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 9, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, disconnect the two wires from the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 29
Duração total: 872
