Ir para o conteúdo principal
Lenovo 500e Chromebook 2nd Gen Motherboard Replacement
O que você precisa
  1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 2, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 2, imagem 2 %32
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 3, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 3, imagem 2 %32
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Battery: passo 4, imagem 1 %32
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 5, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 5, imagem 2 %32
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Remove the three 4 mm screws (six total) from the left and right side brackets using a Phillips #00 screwdriver.
    • Gently remove the metal brackets from the motherboard.
  8. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 8, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the nine 4 mm screws from the motherboard using a Phillips #00 screwdriver.
  9. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 9, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 9, imagem 2 %32
    • Gently remove the USB port from the side housing using an iFixit opening tool.
  10. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 10, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 10, imagem 2 %32
    • Gently peel the metal strip away from the metal backing.
  11. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the single 3 mm screw that holds the Wi-Fi card in place using a Phillips #00 screwdriver.
  12. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 12, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 12, imagem 2 %32
    • Disconnect the Wi-Fi card from the motherboard using an iFixit opening tool.
  13. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 13, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 13, imagem 2 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 13, imagem 3 %32
    • Using an iFixit opening tool, disconnect the camera cable.
    • Potential for device damage: Be gentle while removing the wire.
  14. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 14, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 14, imagem 2 %32
    • Using an iFixit opening tool, detach the speaker wiring from the motherboard.
    • Set speakers aside for reinstallation.
  15. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 15, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 15, imagem 2 %32
    • Using an iFixit opening tool, detach the track pad connector from the motherboard.
    • Potential for device damage: Be gentle while detaching the connector.
  16. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 16, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 16, imagem 2 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 16, imagem 3 %32
    • Using an iFixit opening tool, detach the keyboard cable from the motherboard.
    • Potential for device damage: Be gentle when detaching the cable.
  17. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 17, imagem 1 %32 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 17, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, disconnect the black cable from the motherboard.
    • Potential for device damage: Be gentle while detaching the cable.
  18. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: passo 18, imagem 1 %32
    • Gently remove the motherboard from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 47
Duração total: 742
