Ir para o conteúdo principal
Lefant M210 Wheel Assembly Replacement
O que você precisa
  1. Lefant M210 Wheel Assembly Replacement, Brush: passo 1, imagem 1 %32 Lefant M210 Wheel Assembly Replacement, Brush: passo 1, imagem 2 %32
    • Turn off the Lefant M210 and disconnect it from the charging dock.
    • Flip the unit over so the bottom faces upward.
    • Locate the circular brush assemblies on the left and right sides of the underside.
    • Place the unit on a clean, flat surface to prevent scratching.
    Pergunte ao FixBot
    Comentar
  2. Lefant M210 Wheel Assembly Replacement: passo 2, imagem 1 %32 Lefant M210 Wheel Assembly Replacement: passo 2, imagem 2 %32 Lefant M210 Wheel Assembly Replacement: passo 2, imagem 3 %32
    • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
    • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
    • Remove the brush assembly completely and set it aside.
    • If replacing both brush assemblies, repeat this process on the other side.
    • Avoid using excessive force, which may damage the mounting clips.
    Pergunte ao FixBot
    Comentar
    • Position the new brush assembly above the square mounting peg.
    • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
    • Press down firmly on the brush assembly until you hear or feel it click into place.
    • Gently tug on the brush to verify it is securely seated.
    • The brush should sit flush with the housing and not move when pulled gently.
    Pergunte ao FixBot
    Comentar
  3. Lefant M210 Wheel Assembly Replacement, Wheel Assembly: passo 4, imagem 1 %32
    • Use a Phillips screwdriver to remove four screws near each wheel.
    Pergunte ao FixBot
    Comentar
  4. Lefant M210 Wheel Assembly Replacement: passo 5, imagem 1 %32 Lefant M210 Wheel Assembly Replacement: passo 5, imagem 2 %32
    • Remove the plastic cover next to each wheel.
    • Grip both sides of the wheel and pull upwards.
    • The wheels of the device require some force to remove.
    • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
    Pergunte ao FixBot
    Comentar
  5. Lefant M210 Wheel Assembly Replacement: passo 6, imagem 1 %32 Lefant M210 Wheel Assembly Replacement: passo 6, imagem 2 %32 Lefant M210 Wheel Assembly Replacement: passo 6, imagem 3 %32
    • Hold the wheel up and detach the connector to release it from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Adrian pg
Membro desde: 09/09/24
147 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 2-4, Kershman Fall 2024 Membro de CSU Los Angeles, Team 2-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G4
4 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 45
Últimos 30 dias: 168
Ao todo: 1,996
