Ir para o conteúdo principal
Lefant M210 Brush Replacement
O que você precisa
    1. Lefant M210 Brush Replacement, Brush: passo 1, imagem 1 %32 Lefant M210 Brush Replacement, Brush: passo 1, imagem 2 %32
      • Turn off the Lefant M210 and disconnect it from the charging dock.
      • Flip the unit over so the bottom faces upward.
      • Locate the circular brush assemblies on the left and right sides of the underside.
      • Place the unit on a clean, flat surface to prevent scratching.
      Pergunte ao FixBot
      Comentar
    2. Lefant M210 Brush Replacement: passo 2, imagem 1 %32 Lefant M210 Brush Replacement: passo 2, imagem 2 %32 Lefant M210 Brush Replacement: passo 2, imagem 3 %32
      • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
      • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
      • Remove the brush assembly completely and set it aside.
      • If replacing both brush assemblies, repeat this process on the other side.
      • Avoid using excessive force, which may damage the mounting clips.
      Pergunte ao FixBot
      Comentar
      • Position the new brush assembly above the square mounting peg.
      • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
      • Press down firmly on the brush assembly until you hear or feel it click into place.
      • Gently tug on the brush to verify it is securely seated.
      • The brush should sit flush with the housing and not move when pulled gently.
      Pergunte ao FixBot
      Comentar
Conclusão
If problems occur: Power off the unit, flip it over, and verify the brush is correctly aligned and fully seated. With fresh brushes installed, your robot vacuum is back in action and ready to keep your floors spotless!
Brittany I
Membro desde: 09/09/24
173 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 2-4, Kershman Fall 2024 Membro de CSU Los Angeles, Team 2-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G4
4 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 75
Ao todo: 515
