Ir para o conteúdo principal
Lefant M210 Battery Replacement
O que você precisa
  1. Lefant M210 Battery Replacement, Brush: passo 1, imagem 1 %32 Lefant M210 Battery Replacement, Brush: passo 1, imagem 2 %32
    • Turn off the Lefant M210 and disconnect it from the charging dock.
    • Flip the unit over so the bottom faces upward.
    • Locate the circular brush assemblies on the left and right sides of the underside.
    • Place the unit on a clean, flat surface to prevent scratching.
    Pergunte ao FixBot
    Comentar
  2. Lefant M210 Battery Replacement: passo 2, imagem 1 %32 Lefant M210 Battery Replacement: passo 2, imagem 2 %32 Lefant M210 Battery Replacement: passo 2, imagem 3 %32
    • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
    • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
    • Remove the brush assembly completely and set it aside.
    • If replacing both brush assemblies, repeat this process on the other side.
    • Avoid using excessive force, which may damage the mounting clips.
    Pergunte ao FixBot
    Comentar
    • Position the new brush assembly above the square mounting peg.
    • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
    • Press down firmly on the brush assembly until you hear or feel it click into place.
    • Gently tug on the brush to verify it is securely seated.
    • The brush should sit flush with the housing and not move when pulled gently.
    Pergunte ao FixBot
    Comentar
  3. Lefant M210 Battery Replacement, Wheel Assembly: passo 4, imagem 1 %32
    • Use a Phillips screwdriver to remove four screws near each wheel.
    Pergunte ao FixBot
    Comentar
  4. Lefant M210 Battery Replacement: passo 5, imagem 1 %32 Lefant M210 Battery Replacement: passo 5, imagem 2 %32
    • Remove the plastic cover next to each wheel.
    • Grip both sides of the wheel and pull upwards.
    • The wheels of the device require some force to remove.
    • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
    Pergunte ao FixBot
    Comentar
  5. Lefant M210 Battery Replacement: passo 6, imagem 1 %32 Lefant M210 Battery Replacement: passo 6, imagem 2 %32 Lefant M210 Battery Replacement: passo 6, imagem 3 %32
    • Hold the wheel up and detach the connector to release it from the device.
    Pergunte ao FixBot
    Comentar
  6. Lefant M210 Battery Replacement, Dustbin Filters: passo 7, imagem 1 %32
    • Open the dustbin compartment.
    Pergunte ao FixBot
    Comentar
  7. Lefant M210 Battery Replacement: passo 8, imagem 1 %32 Lefant M210 Battery Replacement: passo 8, imagem 2 %32
    • With your hands, gently pull the dustbin to remove it from its compartment.
    Pergunte ao FixBot
    Comentar
  8. Lefant M210 Battery Replacement: passo 9, imagem 1 %32
    • With your hands, pull off the filter compartment from the dustbin.
    Pergunte ao FixBot
    Comentar
  9. Lefant M210 Battery Replacement: passo 10, imagem 1 %32
    • Pull off the filter from the filter compartment.
    Pergunte ao FixBot
    Comentar
  10. Lefant M210 Battery Replacement, Battery: passo 11, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the six screws around the bottom edge of the device.
    Pergunte ao FixBot
    Comentar
  11. Lefant M210 Battery Replacement: passo 12, imagem 1 %32 Lefant M210 Battery Replacement: passo 12, imagem 2 %32
    • Carefully flip the vacuum back right-side-up, making sure you're holding it all together so that the bottom portion doesn't fall out.
    • Rotate the vacuum so that the Lefant logo is facing you.
    • Carefully lift the white cover of the vacuum, opening it like a laptop, from front to back.
    • Rest the open cover something stable, like a wall.
    Pergunte ao FixBot
    Comentar
  12. Lefant M210 Battery Replacement: passo 13, imagem 1 %32 Lefant M210 Battery Replacement: passo 13, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the three screws securing the motherboard to the device.
    Pergunte ao FixBot
    Comentar
  13. Lefant M210 Battery Replacement: passo 14, imagem 1 %32
    • Carefully lift the motherboard, ensuring you don't rip any cables that are connected to it.
    • The battery should be under the motherboard.
    Pergunte ao FixBot
    Comentar
  14. Lefant M210 Battery Replacement: passo 15, imagem 1 %32 Lefant M210 Battery Replacement: passo 15, imagem 2 %32
    • Push the two retaining clips away from the battery while pulling the battery up from the tabs attached to it to free it.
    • Retaining clips
    • Battery tabs
    • Work on freeing one side at a time so that it's easier to free the battery.
    Pergunte ao FixBot
    Comentar
  15. Lefant M210 Battery Replacement: passo 16, imagem 1 %32
    • When the battery is free from it's housing, lift it out completely using its pull tabs.
    Pergunte ao FixBot
    Comentar
  16. Lefant M210 Battery Replacement: passo 17, imagem 1 %32 Lefant M210 Battery Replacement: passo 17, imagem 2 %32
    • Locate the battery connection wire and carefully pull apart the connection.
    • Pinch the motherboard's wire connector and pull the connection apart.
    • The connection is secured by a clothespin-like mechanism.
    • When you replace your battery with a new one, allow the robot vacuum to fully charge for a few hours before using it again.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Darien Amador
Membro desde: 09/09/24
300 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 2-4, Kershman Fall 2024 Membro de CSU Los Angeles, Team 2-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G4
4 Membros
Autoria de 13 guias
5Comentários do guia
Great guide! Any knowledge on how or why mine beeps twice even when it is on the ground?
Jonathan Manuel - Responder Compartilhar
Thank you for the helpful guide, however, after replacing my battery, it definitely has a much shorter lifespan, and it is unable to find the charger before it dies.
Tee Cee - Responder Compartilhar
I thought it was because I needed a new battery. My stops about 1min after start. When I put it back to the charger it indicates battery charged by showing the blue light. Still after 1 min of operation it dies. That's the reason why i want to replace the battery. Is that what yours is doing too even after replacing the battery?
Zed - Responder Compartilhar
Thanks for the guide.
As for those that stumble upon this, mind that ******if you only want to access the battery, steps 10 to 16 are the only on you need.
Sylvain “Neoblasphem” Mourot - Responder Compartilhar
Bought new batt, installed it and same problem. Red light, not charging. I guess it’s dead for good.
Kelly In Cali - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 61
Últimos 7 dias: 261
Últimos 30 dias: 945
Ao todo: 15,205
