Ir para o conteúdo principal
Leapfrog My Own Leaptop Battery Replacement Guide
O que você precisa
    1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: passo 1, imagem 1 %32
      • Flip over device so that back portion of the device is facing you.
      Pergunte ao FixBot
      Comentar
    2. Leapfrog My Own Leaptop Battery Replacement Guide: passo 2, imagem 1 %32
      • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
      • Please note that the screw cannot be removed as it is attached to the battery cover.
      Pergunte ao FixBot
      Comentar
    3. Leapfrog My Own Leaptop Battery Replacement Guide: passo 3, imagem 1 %32 Leapfrog My Own Leaptop Battery Replacement Guide: passo 3, imagem 2 %32
      • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
      • Remove the three AA batteries.
      • Note the direction of the batteries for when reassembling.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
Jonathan Fitzer
Membro desde: 02/10/16
629 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 14-6, Lacy Spring 2016 Membro de USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Membros
Autoria de 6 guias
1Comentário do guia
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 74
Ao todo: 4,558
