Ir para o conteúdo principal
LeapFrog Scribble and Write Speaker Replacement
O que você precisa
  1. LeapFrog Scribble and Write Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Turn your toy over so that the back is facing upward.
  2. LeapFrog Scribble and Write Speaker Replacement: passo 2, imagem 1 %32
    • Using a Phillips #00 screwdriver, unscrew all circled areas.
  3. LeapFrog Scribble and Write Speaker Replacement: passo 3, imagem 1 %32
    • Very carefully, remove the back case to reveal the contents of the toy.
  4. LeapFrog Scribble and Write Speaker Replacement: passo 4, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the screw highlighted in the image.
  5. LeapFrog Scribble and Write Speaker Replacement: passo 5, imagem 1 %32
    • Un-solder the wiring from the speaker and motherboard.
    • Caution: Be careful when using a soldering iron. Improper usage may result in burns.
Conclusão
Anthony Kidd
Membro desde: 02/10/16
256 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-5, Nance Spring 2016 Membro de USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 989
