Ir para o conteúdo principal
LeapFrog LeapPad2 Explorer Back Camera Replacement
O que você precisa
  1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: passo 1, imagem 1 %32 LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: passo 1, imagem 2 %32
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
    Pergunte ao FixBot
    Comentar
  2. LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 2, imagem 1 %32 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 2, imagem 2 %32 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 2, imagem 3 %32
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
    Pergunte ao FixBot
    Comentar
  3. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: passo 3, imagem 1 %32 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: passo 3, imagem 2 %32
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
    Pergunte ao FixBot
    Comentar
  4. LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 4, imagem 1 %32 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 4, imagem 2 %32 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 4, imagem 3 %32
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
    Pergunte ao FixBot
    Comentar
  5. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: passo 5, imagem 1 %32 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: passo 5, imagem 2 %32
    • Locate the back camera below the game cartridge.
    Pergunte ao FixBot
    Comentar
  6. LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 6, imagem 1 %32 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 6, imagem 2 %32
    • To safely remove the ribbon cable, first you must pull up the retaining flap.
    • Removing or reinserting the cable by brute force can damage it.
    Pergunte ao FixBot
    Comentar
  7. LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 7, imagem 1 %32 LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 7, imagem 2 %32
    • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
    Pergunte ao FixBot
    Comentar
  8. LeapFrog LeapPad2 Explorer Back Camera Replacement: passo 8, imagem 1 %32
    • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
    Pergunte ao FixBot
    Comentar
Conclusão
Nupur Garg
Membro desde: 04/12/14
867 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 8-10, Regan Spring 2014 Membro de Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 25
Ao todo: 1,518
