Ir para o conteúdo principal
LeapFrog LeapPad Ultra XDi USB Charge Port Replacement
O que você precisa
  1. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Battery: passo 1, imagem 1 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Battery: passo 1, imagem 2 %32
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 2, imagem 1 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 2, imagem 2 %32
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 3, imagem 1 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 3, imagem 2 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 3, imagem 3 %32
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 4, imagem 1 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 4, imagem 2 %32
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 5, imagem 1 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 5, imagem 2 %32
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 6, imagem 1 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 6, imagem 2 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 6, imagem 3 %32
    • Use the Spudger to remove the glued down battery.
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Replace the battery with a new one.
  7. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Charging Port: passo 7, imagem 1 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Charging Port: passo 7, imagem 2 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Charging Port: passo 7, imagem 3 %32
    • Locate the three ribbon cables on top of the motherboard.
    • Flip up the locking clip on the ribbon cable connector to release the cable.
    • Disconnect the cables from their connectors.
  8. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 8, imagem 1 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 8, imagem 2 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 8, imagem 3 %32
    • Unscrew the four 5.0 mm Phillips #0 screws securing the motherboard.
  9. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 9, imagem 1 %32 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 9, imagem 2 %32
    • Lift the motherboard up to expose the fourth ribbon cable underneath.
    • Flip up the locking clip to release the cable, and disconnect the cable from the connector.
  10. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: passo 10, imagem 1 %32
    • Locate the charging port on the side of the motherboard.
    • Use a soldering iron to desolder the five metal connections to the motherboard. Replace the USB charge port.
Conclusão
Rachel Baker
Membro desde: 09/01/19
109 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 28
Duração total: 1,211
