Introdução
In this guide, you will be instructed step-by-step through the replacement process of your broken Le Pan S screen. Please note that this screen is attached to the plastic casing using adhesives and will require special attention during the steps outlined below. The LCD display will be removed first in order to prevent potential damage to the parts. Pay careful attention when using the heat gun or blow dryer in order to avoid skin burns.
O que você precisa
Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
Flip the device over to the front.
Use a heat gun or hairdryer to help loosen any adhesive present on the screen. Start with a low, evenly applied heat and slowly increase the temperature as needed.
Use the plastic spudger and the plastic opening tool to prop the screen off of the adhesive at one corner.
Uma outra pessoa concluiu este guia.
1Comentário do guia
Where can I find the replacement display screen for my Lepan TC802a tablet.
James
jrmpr@aol.com
