Introdução
If the battery is too low for the device to turn on, replacing the battery may be necessary. If the device does not turn on after charging, the battery is most likely completely dead. When a battery is completely discharged, it oftentimes cannot be recharged. In this case, the battery is dead and needs to be replaced. No special skills or tools will be needed in order to complete this guide.
O que você precisa
Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
3 outras pessoas executaram este guia.
5Comentários do guia
where can I purchase a battery for a tc978
Hi Timothy, Did you ever find out where to purchase a battery for your Le Pan S tablet?
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
Where can I purchase the battery needed?????????????????
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
