Ir para o conteúdo principal
Le Pan II Screen Replacement
O que você precisa
    1. Le Pan II Screen Replacement, Screen: passo 1, imagem 1 %32 Le Pan II Screen Replacement, Screen: passo 1, imagem 2 %32
      • Insert metal spudger between front and back panel to pry apart.
      • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
      • Avoid using metal when opening devices, as it can damage or crack the screen.
      Pergunte ao FixBot
      Comentar
    2. Le Pan II Screen Replacement: passo 2, imagem 1 %32 Le Pan II Screen Replacement: passo 2, imagem 2 %32
      • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
      • Disconnect the flat ribbon by gently pulling it out from its connecting port.
      Pergunte ao FixBot
      Comentar
    3. Le Pan II Screen Replacement: passo 3, imagem 1 %32 Le Pan II Screen Replacement: passo 3, imagem 2 %32
      • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
      • Disconnect the display cable by gently pulling it out from its connecting port.
      Pergunte ao FixBot
      Comentar
    4. Le Pan II Screen Replacement: passo 4, imagem 1 %32
      • Remove grey metal backing from screen.
      Pergunte ao FixBot
      Comentar
    5. Le Pan II Screen Replacement: passo 5, imagem 1 %32
      • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
      Pergunte ao FixBot
      Comentar
    6. Le Pan II Screen Replacement: passo 6, imagem 1 %32
      • Lift and carefully remove the LCD display from the front cover.
      Pergunte ao FixBot
      Comentar
Conclusão
Kelly Moniz
Membro desde: 10/20/16
525 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 6-3, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-3, Martin Fall 2016
UMASSD-MARTIN-F16S6G3
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 20
Ao todo: 537
