Ir para o conteúdo principal
LTT Introductory Guide for Creating a Media Server
Vídeo de Apresentação
    • To get things ready you are going to want to open your machine up and give it a good dusting, and depending on how old it is, maybe replace the thermal paste.
    • Once your PC has been cleaned, plug it in and reset it to factory default settings. You can do this by hitting the Windows key and typing 'Reset' and hitting 'Get Started'.
    • If you are running Windows 7 or 8 then now would be a good time to upgrade to Windows 10 or 11.
    • In the video, it is reccomened that Winaero Tweaker is used to kill any background tasks that may slowdown your server.
    • While Winaergo Tweaker can be used for this task, MSConfig can be used for configuring what programs should not run on startup.
Conclusão
Congratulation, you have just created your first media server! But, as stated, this is meant to act as an introduction to server creation and management.
Jacob Mehnert
Membro desde: 10/18/21
44.314 Reputação
Autoria de 51 guias
Equipe
iFanatics Membro de iFanatics
Community
63 Membros
Autoria de 219 guias
4Comentários do guia
For the author:
In the Introduction you add the link for Unraid that is not RAID and is a OS meant to be a NAS and it's different from disk management on Windows.
Marc developer - Responder
Hey there @mv_dev, thank you for the catch on that one! I've made the correction for the guide for future clarity.
Jacob Mehnert -
For a NAS there is always Linux, though with the steep learning curve caveat. If you use an old desktop, those can drain quite a bit of electricity. If you want a media server (or a backup server) you could always shut it off when not in use. Also, with Linux, your NAS need not be only a NAS. Using USB serial cords or PCI serial cards, you could control serial to relay cards to control stuff with shell scripts but see the above caveat. Christmas light show server, anyone?
Michael Poulos - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 112
Ao todo: 3,263
