Ir para o conteúdo principal
LG X Power Charging Port Replacement
O que você precisa
  1. LG X Power Charging Port Replacement, LG X Power Disassembly: passo 1, imagem 1 %32 LG X Power Charging Port Replacement, LG X Power Disassembly: passo 1, imagem 2 %32
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Charging Port Replacement: passo 2, imagem 1 %32 LG X Power Charging Port Replacement: passo 2, imagem 2 %32
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Charging Port Replacement: passo 3, imagem 1 %32 LG X Power Charging Port Replacement: passo 3, imagem 2 %32
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Charging Port Replacement, Charging Port: passo 4, imagem 1 %32 LG X Power Charging Port Replacement, Charging Port: passo 4, imagem 2 %32 LG X Power Charging Port Replacement, Charging Port: passo 4, imagem 3 %32
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Charging Port Replacement: passo 5, imagem 1 %32
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Charging Port Replacement: passo 6, imagem 1 %32
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Charging Port Replacement: passo 7, imagem 1 %32
    • Desolder the MicroUSB charging port from the motherboard.
    • If you need help soldering, follow this guide.
Conclusão
5 outras pessoas executaram este guia.
Chad Sears
Membro desde: 02/14/18
1.149 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G6, Nance Spring 2018 Membro de USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
Membros da 3
Autoria de 12 guias
Um comentário
Where can i get the charging port part? There are so many different usb female ports.
Wayne Newell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 5,918
