Ir para o conteúdo principal
LG VX8700 Ear Piece Replacement
O que você precisa
  1. LG VX8700 Ear Piece Replacement, Battery: passo 1, imagem 1 %32 LG VX8700 Ear Piece Replacement, Battery: passo 1, imagem 2 %32
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
    Pergunte ao FixBot
    Comentar
  2. LG VX8700 Ear Piece Replacement: passo 2, imagem 1 %32 LG VX8700 Ear Piece Replacement: passo 2, imagem 2 %32
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
    Pergunte ao FixBot
    Comentar
  3. LG VX8700 Ear Piece Replacement, Front Bezel: passo 3, imagem 1 %32
    • Turn your phone around and open the flip phone. The screen is now facing you.
    • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
    • Remove the two grey screw-covers.
    Pergunte ao FixBot
    Comentar
  4. LG VX8700 Ear Piece Replacement: passo 4, imagem 1 %32 LG VX8700 Ear Piece Replacement: passo 4, imagem 2 %32
    • Use the ejection tab at the top to remove the screen.
    • There is a gap between the case and the screen near the ear piece.
    • Insert the plastic opening tool in the gap and pry up the screen.
    • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
    Pergunte ao FixBot
    Comentar
  5. LG VX8700 Ear Piece Replacement: passo 5, imagem 1 %32
    • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
    Pergunte ao FixBot
    Comentar
  6. LG VX8700 Ear Piece Replacement: passo 6, imagem 1 %32 LG VX8700 Ear Piece Replacement: passo 6, imagem 2 %32
    • Turn your phone around. The battery side will be facing you.
    • Insert the plastic opening tool into the groove to remove the top cover of the phone.
    • Carefully open the cover.
    Pergunte ao FixBot
    Comentar
  7. LG VX8700 Ear Piece Replacement, Ear Piece: passo 7, imagem 1 %32
    • Locate the earpiece, which is the black component at the top with black and red wires.
    • Remove the component. Using a soldering iron, desolder the top ear piece.
    Pergunte ao FixBot
    Comentar
  8. LG VX8700 Ear Piece Replacement: passo 8, imagem 1 %32 LG VX8700 Ear Piece Replacement: passo 8, imagem 2 %32
    • Using the plastic opening tool, lift the earpiece to remove it from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 8-16, Maness Winter 2012 Membro de Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 1,354
