Ir para o conteúdo principal
LG VX5500 Audio Port Replacement
O que você precisa
  1. LG VX5500 Audio Port Replacement, Battery: passo 1, imagem 1 %32 LG VX5500 Audio Port Replacement, Battery: passo 1, imagem 2 %32 LG VX5500 Audio Port Replacement, Battery: passo 1, imagem 3 %32
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
    Pergunte ao FixBot
    Comentar
  2. LG VX5500 Audio Port Replacement, Audio Port: passo 2, imagem 1 %32 LG VX5500 Audio Port Replacement, Audio Port: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
    Pergunte ao FixBot
    Comentar
  3. LG VX5500 Audio Port Replacement: passo 3, imagem 1 %32 LG VX5500 Audio Port Replacement: passo 3, imagem 2 %32 LG VX5500 Audio Port Replacement: passo 3, imagem 3 %32
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
    Pergunte ao FixBot
    Comentar
  4. LG VX5500 Audio Port Replacement: passo 4, imagem 1 %32 LG VX5500 Audio Port Replacement: passo 4, imagem 2 %32
    • Locate the audio port; this is what it should look like.
    • The audio port is mounted and connected at 6 points. Check the integrity of these connections.
    • If any of the connections are dislodged or the audio port is damaged, desolder the port and install a new one.
    Pergunte ao FixBot
    Comentar
Conclusão
Kurt Beske
Membro desde: 05/07/12
70 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-33, Maness Spring 2012 Membro de Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 26
Ao todo: 768
