Ir para o conteúdo principal
LG VX5400 Phone Casing Replacement
O que você precisa
  1. LG VX5400 Phone Casing Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the cell phone and turn it over on its back side
    Pergunte ao FixBot
    Comentar
  2. LG VX5400 Phone Casing Replacement: passo 2, imagem 1 %32
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
    Pergunte ao FixBot
    Comentar
  3. LG VX5400 Phone Casing Replacement: passo 3, imagem 1 %32 LG VX5400 Phone Casing Replacement: passo 3, imagem 2 %32 LG VX5400 Phone Casing Replacement: passo 3, imagem 3 %32
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
    Pergunte ao FixBot
    Comentar
  4. LG VX5400 Phone Casing Replacement, Outer Casing: passo 4, imagem 1 %32
    • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
    Pergunte ao FixBot
    Comentar
  5. LG VX5400 Phone Casing Replacement: passo 5, imagem 1 %32
    • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
    Pergunte ao FixBot
    Comentar
  6. LG VX5400 Phone Casing Replacement, Phone Casing: passo 6, imagem 1 %32 LG VX5400 Phone Casing Replacement, Phone Casing: passo 6, imagem 2 %32 LG VX5400 Phone Casing Replacement, Phone Casing: passo 6, imagem 3 %32
    • Pry open the phone and remove the keypad and logic board.
    Pergunte ao FixBot
    Comentar
  7. LG VX5400 Phone Casing Replacement: passo 7, imagem 1 %32 LG VX5400 Phone Casing Replacement: passo 7, imagem 2 %32
    • Lay out and organize the parts of the phone. You can now put the inner parts of the phone into the new case.
    Pergunte ao FixBot
    Comentar
Conclusão
Tyler
Membro desde: 04/15/10
20 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 26-26, Regan Spring 2010 Membro de Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 2,633
